Catalyzer not installing.
Damsel
OK, so I tried to install Catalzyer through Smart Content. Bought it years ago. So I hit the little catalyzer button, which appears to be installed, but all that's there is the manual. It's not listed among the pluggins. So I downloaded it through DIM, and once again, all I got was the manual. So I manually downloaded it. Tried to install it. It still isn't there in pluggins. What gives?
Some (many? most?) plugins won't install properly if Studio is running at the time. If that was the case, uninstall Catalyzer from all attempts to install it (manual, Connect, DIM). Close DAZ Studio and try to install it from DIM. Open Studio and enter the serial no. in About Installed Plugins, then restart Studio again.
Thanks!
The install path for this plugin is weird. It reads: DAZ 3D\Installed Content\LAMH2Iray Catalyzer for DAZ Studio 4.8+ (Win 64-bit) Shouldn't it install in the plugin folder? But when I looked in the plugin folder, I don't see anything that says LAMH Catalyzer.
Where are you looking? If you installed with DIM, right-click on "LAMH2Iray Catalyzer for DAZ Studio 4.8+ (Win 64-bit)" and select "Show Installed FIles..." and you should get something that looks like the attached.
