Daz Studio 3 won't render anything
Every time I try to render something direct to file in Daz Studio 3, the rendering lasts about 2 seconds and then spits out a mostly blank picture with maybe 2 or 3 pixels actually rendered. This isn't a problem when rendering in viewport, but when rendering to file this ALWAYS happens. Has anyone else ever had this issue? Is there a solution?
  • mclaughmclaugh Posts: 221
    GPU rendering only or GPU and CPU? Does it work for other rendering types (OpenGL, 3DL, iray (not sure DS3 supports iray: pretty sure it doesn't))?
    I'm currently battling a problem with iray not rendering unless CPU rendering is enabled. May be worth trying various render types and device combinations (CPU + GPU, CPU only, GPU only) if you haven't already.
  • AtiAti Posts: 9,208
    Are your video drivers up-to-date?
  • LeanaLeana Posts: 13,512
    DS3 definitely doesn't support Iray, it was introduced in 4.8, and there's no "GPU vs CPU" device selection either.
    Do you render with 3DL or OpenGL? I never had any problem rendering to file with 3DL, but I never tried with OpenGL.
