Can more than one DAZ Studio versions installed parallel on a computer?
Can more than one DAZ Studio versions installed  parallel on a computer accessing one DAZ lib  - eg. 4.10 and a version higher 4.10?
Are there any things you must be aware of?
  • This question was/is already discussed on "Ability to run two different Daz Studios on one computer?"
  • LeanaLeana Posts: 13,512
    edited September 2019
    Only if one is a 32 bits version and the other 64 bits, or if one is a general release and the other a beta. Other combinations could cause problems as both versions would share directories with technical files, and the newer version may require updates to those files which may not be compatible with the older version, or there could be conflicting accesses to those files.
    Post edited by Leana on
