Viewport has gone white from gray and I can't change it back
I did a !Preload on a set or scene and now my viewport is white instead of gray. For the life of me I can't find the setting to fix it. Can someone help a brother out?
THANKS!
Yes, this is the second issue I posed in like 10 minutes. It's not been a productive Saturday.
  • LeanaLeana Posts: 13,504
    You can select the backdrop color in the “Environment” tab.
  • NorthOf45NorthOf45 Posts: 5,896
    It is most likely one of two things, the environment backdrop or the UI settings. First check the Environment tab to see if the type has been set to Backdrop (which would have diffuse set to 0,0,0). If so, just set the type to None. Otherwise, from the top menu, open, Window -> Style -> Customize Style. In the popup, go to Viewports and see if the colour is set to 0,0,0. I believe the default is 68,68,68.
  • AabacusAabacus Posts: 407
    I checked out @Leana and your solutions and found yours first. My environment tab is empty...so...I'll solve that problem another day. Thanks!!!!!!! Fixed it. Sheesh, that was annoying.
