Mirror effects - steamed / frosted
I've just started playing around with Daz studio, can anyone help me getting a steamed-up bathroom mirror effect? I've played with the surface settings a little bit with a perfectly reflecting mirror surface to see what happens but I just can't seem to get the effect I'm after.
Thanks!
  • felisfelis Posts: 6,508
    edited September 2019
    I think it will be hard to obtain just using the sliders.
    My suggestion would be to use a shader like this
    https://www.daz3d.com/glassfx--iray-shaders
    Edit: you might have to apply a geoshell to the mirror, and put the glass shader in that, and keep the mirror with current surface
    Post edited by felis on
  • AbnerKAbnerK Posts: 718
    You would need normal/bump/maps for your surface settings. If you're just starting out I would look at shaders that you've got and try to understand what they're doing. It might be a lot easier to get the product suggested above.
