Objects return deformed and misplaced from Zbrush
rickfoxxx74331700rickfoxxx74331700 Posts: 186
edited December 1969 in Poser Discussion
I hope someone can help me with this problem:
I have a prop sofa, which is part of a room. I export it to Zbrush:
Object - Export Object Mesh to GOZ - check "Export Posed" - check "Object part"
I work it on Zbrush but when I active the morph to "1" the prop sofa gets deformed and moves away from its original location.
Does anyone happened the same with objects in Zbrush?
Thanks in advance.
  • AscaniaAscania Posts: 1,856
    Moves away?
    You imported to the wrong scale or you moved the object.
  • rickfoxxx74331700rickfoxxx74331700 Posts: 186
    Ascania said:
    Moves away?
    When I export the object checking "Export Posed" returns deformed, but when I export no checking "Export Posed" returns right...
