Can't Do Faye Hair with 4GB Nvidia 1050
NylonGirl
So I got Faye Hair.
https://www.daz3d.com/dforce-faye-hair-for-genesis-3-and-8-females
Any time I try to render even a single character with this using the GPU, it fails. I can render the same character with the GPU just by changing to a different hair. I have rendered the character with the Faye hair using the CPU instead of the GPU. What's going on? Is Faye Hair exceeding the 4 gigabytes of video ram all by itself? If it is, should I be returning it on the grounds that it has an unreasonable system requirement?
I think the character I used was Babina 8. And normally I can render multiple characters with hair, clothes, and an HDRI within that 4GB of space.
dForce hair can be quite demanding, because of all the strands (which get turned into real geometry for Iray). Depending on the render you might be able to lower some texture resolutions.
