facegen can't find DS
FSMCDesigns
Just reinstalled facegen and it says DS is not installed even though it is. I used DIM this time around which installed the library outside of my documents. Any way to tell Facegen how to see Daz Studio so I can start using it?
FaceGen doesn't need to see DAZ Studio when you run it & create your faces, but when it comes time to export a morph to DAZ Studio and you go to those tabs (Genesis, G2F, G2M, G3F, G3M, G8F, G8M so 7 tabs in all) to export to DAZ Studio you'll see a pre-filled out path to the appropriate morph folder location in your DAZ Studio content library. Similar when you choose whether or not you want to get FaceGen to combine the texture set it made with your image used to make the morph & it's own set of textures with a DAZ Studio set of textures to make a new set of textures just for the morph you just created.
If so, then why does it say DS is not installed and give me this error?
Hmmm OK, that's changed since they starting selling the product in the DAZ 3D Store.
Here is there support link so you can ask them directly:
https://facegen.com/support.htm
Thanks, found the solution there.
