Some morphs and poses cause the head to pierce through the hair
hi guys. Applying some morphs and poses with GF3 will cause the head to pierce the hair.
It seems to occur with hairstyles with bones in the hair. Smoothing Modifier had no effect. Is there any solution?
by the way, This is the hairstyle used in the image.
1321 x 825 - 242K
1337 x 863 - 199K
Smoothing Modifier with the base figure set as the Collision Target? Is it a problem in renders, or only in the preview?
Yes, there was no point in using Smoothing Modifier because the effect was applied to the scalp part. The same problem occurs with both renders and previews.
I've had this problem with hairs before, especially this one: https://www.daz3d.com/lyall-hair-for-genesis-3-8-male-s
Never found a solution.
