Lights! Where are they coming from?
tdc
As you can see, I've made a planet. I added one spotlight... Not only is it completely illuminated but the shadow is going in the wrong direction! I want there to be a darkside as if a sun is shining on it.
Advice?
3394 x 1946 - 1M
Check your render settings. If the only light you want is the spotlight, then go to the Environment tab and select "scene only" under Environment Mode.
edit: also, the way lights work in Daz, you may not be seeing the spotlight at all. Lights in Daz default to 1500 lumen/m^2, which isn't very much. Go into the light settings and add a few zeroes to the Luminous Flux property, and/or the cm^2 factor in Render Settings / Tone Mapping.
