Poses missing from FG Dusty Basement With Poses For Genesis 8 Female(s)
vonHobovonHobo Posts: 1,715
https://www.daz3d.com/fg-dusty-basement-with-poses-for-genesis-female-s
Purchased this new product today and could not find any poses included with the environment.
It was listed in Smart Content in both the Environments and Poses sections, but it has absolutely no poses included.
Am I missing something?
Post edited by vonHobo on
  • What about in the Content Library pane, under Daz Studio Formats>content library>Environments>Architecture>Fugazi1968>FG Dusty Basement>Poses and then sub-folders? The file List says they should be there http://docs.daz3d.com/doku.php/public/read_me/index/62761/file_list
  • vonHobovonHobo Posts: 1,715
    Thanks for the info and I will look in the Content Library.
    But can the meta data be updated to put the poses in the Smart Content pane? Every other product I've ever purchased (hundreds of them) from DAZ is set up for the Smart Content pane. Oh well.
    I looked in the Content Library and could not find the poses there either. Nothing under Genesis 8 Female, Poses, and nothing under the product "Go to Content Library Folder" either.
    I will ask DAZ support about this issue I guess.
  • How did you install? If through Install Manager make sure there aren't two zips - though ti seems fairly unlikely. If not then yes, it may well be  apacking error and should be reported to Daz via a ticket - thank you.
  • dragotxdragotx Posts: 1,149
    In the product library on my account page there are two different files (different names for the product as well, which is interesting).  With the exception of the manifest file size, folders using the product name (which match each corresponding zip file), and the internal date being almost a full month different between both files, each file is identical as far as I can tell.  Neither one of them have the pose files included in them, and DIM only downloads one of the files.  I have submitted a support ticket, just posting here as an FYI for anyone looking for the same problem.
    Thank you Dragotx and Richard. I also submitted a support ticket so hopefully this will be fixed soon. smiley
  • nicsttnicstt Posts: 11,715
    try installing through DIM, then right click the installed item > 'Show Installed Files', then find the poses in the list, and as they are a link, they should be easy to find - can click on said link.
  • SevrinSevrin Posts: 6,314
    edited September 2019
    Did you purchase this product?
    There are no poses in the list, all there is is this line in the files list.  Also, the names on the file list do not match what's actually delivered.
    /Environments/Architecture/Fugazi1968/FGDB Dark Basement/Poses.png
    Files list of what was actually delivered is attached.
    With only 4 poses of the 20 advertised shown on product page I guess we should have known this would be trouble.
    Edit: Now that I look at it, there aren't any poses on the files list linked from the product page either.  My guess is that what got shipped is some kind of incomplete early version, which would explain the incorrect names.
    txt
    txt
    Dark Basement Files List.txt
    50K
    Post edited by Sevrin on
    Thank you Sevrin.
    Yes, I purchased the product. I have already sent a trouble ticket to DAZ Support.
    Hopefully it can be fixed soon.
    I do like the environment. It is nicely done, with attention to details. So if we can get the 20 poses mentioned on the product page that would be nice.
    Sevrin said:
    von Hobo said:
    Thank you Sevrin.
    I understood that you had purchased it, but the person giving inappropriate advice probably hadn't.
    Anyway, got an email from support with a Dropbox link for the poses.  It was a zip file like we usually get when using DIM, or that Content Package Assist program, but DIM didn't recognize it.  Manual installation worked fine, though.  I suppose there will be a proper update eventually.  Of all the packages I've purchased from Fugazi or i3D_Lotus , this is the first time I've had a problem, so I won't hold it against them.  With the name mix-up, it probably wasn't even their fault.  With all the packages Daz processes, something's bound to go wrong now and then, and they did provide relief quickly.
    The basement's very nicely done, but it could use more dust.  Doing a quick test with some atmospheric goodness now.
    Sevrin said:
    Sevrin said:
    von Hobo said:
    Thank you Sevrin.
    Thanks for letting me know. They sent me the dropbox link too.
    I'm going to wait for the product update as I don't need the poses immediately.
    This is the first product of any artist, Fugazi included, that has ever been missing poses. So I don't mind waiting. Like you said, mistakes happen. smiley
    All fixed and updated and better now.  I did a render that's in my gallery, but I'm not sure about posting it here on account of I added more than some dust.  I don't think nice things happen in that basement.
    I thought it would be a heavier set than it is, but it's not bad.  I did my first tests with nothing hidden and it all fit, including a dressed and haired figure.  Some of the poses fit very well, but some are kind of generic.
    Thanks Sevrin. I received the update in the DAZ Install Manager. They sure do fix things fast!
