Victoria 4 for Genesis 2 Female
My 3D Spin
I have had this product for a while but still cant figure out how it works?
When i look in the content folder there is just one item there : Set Victoria 4 UV ( I guess thats for the texture)
But i have tried shaping etc. but nothing happens. does anyone know how this works? There seem to be no PDF manual either.
This is the description:
Generation 6, meet Generation 4! Victoria 4 for the Genesis 2 Female, premiere 3D models, gives you a path to use your existing Victoria 4 accessories and textures on your Genesis 2 Female characters. Use the AutoFit clone to access your favorite outfits, the Victoria 4 UV set to use your favorite textures and the Victoria 4 figure shape to see a familiar face.
note: Due to a limitation in how DAZ Studio handles presets, only material presets which are in DUF format can be directly applied. Any existing material presets must be re-saved in DUF format from the original Victoria 4.
There should be a Victoria 4 option (or two, body and head) in the list of shapes available - check in the Parameters pane. The UVs will apply, with a native (.dsf/.duf) materials preset, automatically - if using an older Poser .pz2 then you will need the preset to apply the UV set. The AutoFit clone adds a new source option when using AutoFit.
I have checked the Parameter and shaping tab but there is no Victoria 4 option in there. The Hair and Clothes work ok
with Auto fit.
Ok. Now i found the Victoria 4 Head and body levers but when i turned them up and apply a V4 Face or body
nothing happens?
I also have G3F for G2F an its the same thing nothing happens when i try to load a shape!
I'm not sure what is happening then.
Isint it that wich gives the G2 a V4 shape so that i should be able to apply
V4 shapes to G2. But however i try to load a V4 shape nothing happens.
Is it possible to contact the artis that made the Product?
"when i turned them up and apply a V4 Face or body nothing happens?"
If I understand you correctly, you are attempting to use this utility to apply Victoria 4 character morphs to Genesis 2 Female? If so, it is not designed nor will it work for that purpose. It is only designed to allow the use of V4 texture sets and to autofit V4 clothing to G2F. When the product description says "the Victoria 4 figure shape to see a familiar face", it is referring only to the base V4 shape, no other. To use V4 character morphs with G2F, you need Genesis Generation X2 and the GenX2 AddOn for Genesis 2.
Ok-Thanks for clearing that up!
Now i have purchased Genesis Generation X2 and the GenX2 AddOn for Genesis 2
But how does it work? I can see the Generation X in the shaping tab but it only gives
me 3 options of Characthers to inj. I have 30-40 - V4 Characthers but when i try to
inject their shape on a G2f nothing happens or just the eyes get distorted?
Thankful for any help!
Try this:
http://www.sharecg.com/v/82453/view/3/PDF-Tutorial/GenX-Plugin-Tutorial
