Wrap a texture around a sphere
Is it possible to wrap a golf ball texture around a sphere in Daz Studio? If not, can it be done in Carrara?
  • Wrapping a texture around a model depends on the UV mapping, unless you create a procedural shader in Shader Mixer/Builder.
  • JD_MortalJD_Mortal Posts: 760
    edited September 2019
    Here are a few free golf-ball objects. You may even be able to change the textures to other balls, depending how they are UV-mapped. (That is just a fancy way of saying, "textured". No Ultra-violet maps are used in texturing. :P )
    You want the OBJ or DAE versions, or FBX may work too. (OBJ is more universal, DAE can be buggy, FBX is hit or miss but a potentially better format.)
    https://www.turbosquid.com/Search/3D-Models/free/golf-ball
    After you download it, and unzip it, if it is zipped-up... You go into Daz and go to the [File]->[Import] menu. Then just find the object that you downloaded. (You may have to select OBJ, or DAE or FBX, in the file-types, before it shows the files.)
    Just accept whatever it says, when it opens-up. If it doesn't load correctly, you may want to change some settings when it imports/opens the file. But, normally, if it doesn't display right, you just need some other format of the object to import. Unless it's something simple, like being inside-out, or having a flipped axis.
    Post edited by JD_Mortal on
  • Seven193Seven193 Posts: 1,156
    If you get a golf ball with real dimples, then there's no need for UV mapped textures, unless you want a dirty golf ball or one with stamped logos.  Just apply a glossy white Uber shader to it and you're done.
  • barrieMbarrieM Posts: 307
    Thank you all for your helpful advice. Problem solved, Thanks.
    JD_Mortal. Many thanks for the link. Free golf balls gallore.
