lipsync dmc configuration file editing without mimic
WendyLuvsCatzWendyLuvsCatz Posts: 41,812
I have a number of Poser figures that crash mimic pro
up until now never tried it
but YOU CAN EDIT THE Default .dmc file in notepad
you need to know the morph names and substitute the exact names for those in the default mimic configuration file
capital and lower case count so be exact
if you have no phoneme use open mouth
  • gtbfilezgtbfilez Posts: 2
    Thanks and Happy New Year to ya!
    Garage Tale Basement Files
  • MediaheadMediahead Posts: 120
    edited January 2014
    Happy New Year Wendy!
    Can you please advise how to create a dmc file? I tried modifying an existing file as per your suggestion using notepad, but when saving the file it's saved as a txt file even though the extension is still dmc, mimic won't read it.
    Thanks!
    Post edited by Mediahead on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,812
    save as ALL FILES not txt and ANSI
    As well as ALL FILES, should the encoding be set to unicode or unicode big endian or UTF-8 ?
    ANSI
    edited January 2014
    Thanks Wendy.
    Unfortunately, when I saved it as all files and ANSI it still displays as a text file.
    you do have file extensions visible? and are saving it as file name.dmc
    It was. Interestingly, when I just save and not save as it works as you suggested. So as long as I don't attempt to rename a new edition, the extension maintains its integrity. Thanks again Wendy.
  • faisanfaisan Posts: 602
    could you make a xml file for genesis please? :(
    got your PM, I do not do emails to just anyone
    but could not reply you have a duplicate username with somebody
    I do not know how to do xml files for Poser
  • Richard HaseltineRichard Haseltine Posts: 111,996
    No one in this thread has a duplicate screenname as far as I can see.
    edited January 2014
    I do believe taiuri was ,
    I have a draft message to this name exact request I could not send
    basically same thing I said in thread, I do not know how to do Poser XML files
    venomfangx is disambiguated.
