Problem with morph dials
azazelsteiner6
I'm trying to create a custom body shape but I get this problem when I try to dial a certain number and hit enter it resets to 0.0%. How can I fix this?
306 x 198 - 7K
170 x 243 - 5K
Perhaps it's set to a limit. Look at the gear and what numbers min/max are.
That's not the property from your first post - is it doing exactly the same thing? In the Settings dialogue, what is in the Controllers tab at the bottom?
Hello is this it?
I'm having some issues when I try to create a custom morph from the dials of other custom morphs that I purchased but this is not my only problem. When I save my OC and delete daz and install it again my OC's morphs are missing even if I install my custom morphs, they do not apply on my figure.
I created my OC when daz was 4.10 and it was working perfectly but now my OC is broken.
I only clicked the settings on the custom morph that isn't working properly and t displayed that panel. I apologise for my lack of english because it isn't so great.
and then launch Parameter Settings from there, and look at the Controllers tab.
OK, that eliminates the possible causes I'd thought of. I'm not sure what else to suggest - have you tried rstarting DS and loading a fresh copy of the base figure?
If you are referring to recreate the oc again using the base figure then yes that would work but the problem is I don't remember the correct dials for this.
I created the oc using daz 4.10 and it worked perfectly I never had any issues with daz before this new update of daz 4.11.
I never had problems with custom or original morph dials until now.
