People don't load on ground
Hello, I have a strange loading problem:
If I load a G2F the parameters show 0,0,0. If I hit ctrl+d the Y goes to 0.13
If I load a  G3F the parameters are 0,0,0. If I hit ctrl+d the Y goes to 0.20 so far so good, the feet a little bit stucking in the floor after loading is not nice but ok.
BUT if I load a G8F, she is hovering a lot over the ground, even if the parameters show 0,0,0. If I hit now ctrl+d she goes to -0,73. But optical perfect on the ground. This happens with all G8F figures. The males end on -0.35
What is going on?! I have problemes by importing them into other softwares if I need a 000 location. I don't like the loading position of G8. I could put my Hand between foot and floor. How can I or DAZ fix it?
Anybody else out there with an idea?
  • The zero pose has the legs out to the sides, and so raises the feet off the ground.
  • Ok, thank you Richard, but the inside of the feet is also hovering a lot. They should stay on the floor in my opinion. No?!
  • TheKDTheKD Posts: 2,711
    She was likely modeled in a classic T pose, with feet on floor, then changed to A pose after to help the clothing creators make clothes easier. If you move each leg together by 6, about where the classic t pose legs would be, the feet are flat on the floor.
    I think the actual reference for CTRL-D may be the character bounding box.
  • Aaaah thanks to all. Now I know more. :)
