Supersuit
Hi guys ,
Idk if this is the right place , but can't seem to fined any instructions on Supersuit that is not installing  properly , I've downloaded and installed it several times and it never works ;-(
I get a missing files ( yes many ) error and I have evetrhing on defeault path ..
Can anyone please help ??
Thank you ;-) :)
  • NorthOf45NorthOf45 Posts: 5,813
    Do you mean the Genesis Supersuit? Are you trying to load "Basic Suit" or one of the presets?
  • yes the Genesis supersuit , and I was trying one of the presets , Sovereign ... Any advice ?
    thank you
    Try loading the Basic Suit first, then applying the material preset after (it will look flat because the relief is mostly done with Parameter settings for each... individual... piece... of the suit). What errors are you getting? You can post a listing, or part of it if it's too long.
  • Thank you I will try that .
    This is what I receive every time I try to load the file .
    492 x 291 - 55K
    Looks like the Supersuit itself is not installed. The Sovereign preset is an add-on to the basic Supersuit. Did you just buy the Supersuit Fantasy Pack? You need to get the Genesis Supersuit package for it to be of any use. Today is your lucky day, it is on deep discount, if you want to pursue it further. If not, you can return the Fantasy Pack for a refund if it has been less than 30 days. Or, you could consider one of the Bundles if you have any interest in any of the other add-on sets. Return the Fantasy Pack, and buy the Bundle now, if that's convenient.
