Help with copying/cloning v4 character
michaelmirandamichaelmiranda Posts: 0
I have a v4 character on my 32 bit Vista and I will be moving over to a 64 bit Windows 7. Is there a way for me to export her so that I might load her on the new 64 bit system?
  • Richard HaseltineRichard Haseltine Posts: 111,996
    In which application?
  • michaelmirandamichaelmiranda Posts: 0
    It would be on Daz Studio 4.6. Thanks
    Basically, nothing...
    The content doesn't care if Studio is 32 or 64 bit. In fact, you could simply take your old hard drive and once Studio is installed on the new machine, just copy over your content folders...
    OK, I would a) back up the \Data folder in any of your content directories and b) save both a Scene subset with the character adn any clothes or hair you want in it and a set of presets - character, wearables (with the clothes or hair parented to V4 as well as fitted), materials, and pose. With luck, once you have installed the Victoria files on the new system the Scene Subset will load - if it doesn't the presets should let you rebuild the character fairly quickly.
    Thank you Richard and Addict. That did the trick!
    I made a scene subset and copied my entire content library as well as the scene subsets, and all is well on the new machine.
