Dragon 3: "Dragon 3 Morph" + "The Feathered Dragon HD" ?
Dear,
2 questions:
- is https://www.daz3d.com/raptor-the-feathered-dragon-hd a realistic skin for dragon 3 ?
- is compatible with https://www.daz3d.com/daz-dragon-3-morphs ?
Thanks, Xavi
  • Yes
  • SevrinSevrin Posts: 6,314
    It looks like every dragon I've ever seen.
  • xavieratorxavierator Posts: 161
    edited August 2019
    I'm playing with https://www.daz3d.com/raptor-the-feathered-dragon-hd materials
    1st test fail, the wings are transparent :-(
    And, which is the differences between MDL and RSL materials ?
    Thanks a lot, Xavi
    1277 x 721 - 452K
    2000 x 1800 - 850K
    Post edited by xavierator on
  • GordigGordig Posts: 10,799
    MDL are for Iray, RSL are for 3DL. As for the transparency, there's most likely an opacity map, so if you find the cutout opacity setting and either adjust the setting or remove the map entirely, it should fix the problem. Also, if you look closely, the promo images for Raptor show some transparency on the wings, albeit less pronounced.
    Found, Opacity Active On/Off
    Thanks, Xavi
    514 x 85 - 15K
    2000 x 1800 - 836K
