Gen 8 Female Centaur installation fail
Oaklyn is a real beauty, but I can't render her, because the Fem.Cent. isn't installing properly. Tried it several times. Any ideas?
608 x 714 - 59K
557 x 522 - 67K
  • Is this a Connect install? You could try
    1. uninstall
    2. Connect>Work Ofline
    3. Find the product container in the Content Library pane under Products
    4. Right-click on the container, select Delete
    5. Connect>Login - the product should then reappear after a bit
    6. Install
    If that doesn't work you may need to open a suppot ticket, in the meantime you could unisntalla gain and then install through Install Manager.
  • AncientWireAncientWire Posts: 143
    edited August 2019
    I am having the same problem with Oaklyn.
    G8 Female Centar will not load into my scene.
    I uninstalled and reinstalled G8 Female Centaur.
    The error popup when I try to load G8 F Centaur into my scene said to check the log which says about a hundered times:
    Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_61909/data/daz 3d/genesis 8 centaur/g8female centaur/g8fcentaur.dsf (1,1): Syntax error - expected '{' or '['
    followed by this line about a dozen times:
    Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_61909/data/daz 3d/genesis 8 centaur/female centaur tail/dazcentaurtail.dsf (1,1): Syntax error - expected '{' or '['
    then a morph error, then some more of the whole centaur, then some more of the tail
    then this line:
    WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1908): Could not find geometry definition: /data/DAZ%203D/Genesis%208%20Centaur/G8Female%20Centaur/G8FCentaur.dsf#G8FCentaur-1.
    followed by "could not find geometry" and "failed to create material" about 50 times
    I opened a support ticket
    Post edited by AncientWire on
  • RPGMaker247RPGMaker247 Posts: 146
    edited August 2019
    There be bugs in the centaur 8.
    Post edited by RPGMaker247 on
  • The Blurst of TimesThe Blurst of Times Posts: 2,410
    edited August 2019
    Yeah. Centaur 8 for G8F seems all jacked up.
    I can find Centaur 7 for G3F
    I can see Centaur 8 for G8M in the FEMALE category.
    There's no base Centaur 8, nor any Centaur 8 additive for G8F.
    623 x 557 - 84K
    Post edited by The Blurst of Times on
    1. uninstall
    6. Install
    After the installation through DIM it works, the 1.-6.-procedure failed.
    Thanks a lot Richard
  • evitcanievitcani Posts: 14
    I'm having this same issue. Tried the solutions above and none work. I'll open a support ticket as well.
  • brimstoneomegabrimstoneomega Posts: 343
    edited August 2019
    There are 6 items from the probundle that are broken when installing with connect, as well as today's release of Maxx. There are also a few items that are in lost and found in smart content and as The Burst of Times pointed out the meta data for a lot of things is very messed up
    Post edited by brimstoneomega on
  • I had similar problems as well. G8F centaur wouldn't load at all, but it started working after I installed it through DAZ Install Manager. G8M centaur, meanwhile, loads fine but is catagorized under Female (same problem shown in The Blurst of Times's post); I manually catagorized it under Male, though it still appears under both Male and Female.
  • GordigGordig Posts: 10,805
    I'm having the same problem as well, even extending to the dForce Willow outfit. I've had to install both through DIM or else they just plain won't load.
  • DAZ 3D failed with this version of the centaur set. Here's to hoping they find the problem and the character is fixed. Or offer a refund.
