I´m "crashing" while rendering a certian outfit.
Hi everybody lets cut the chatter short and get to the thing
So i recently bought this maid outfit on renderosyity renderosity.com/mod/bcs/index.php?ViewProduct=125159
and now whenever i want to render or prerender anything i get weird stuff going...
thing is when i prerender/render for first time after opening daz it works qute ok for a couple of moments before my cpu seems to kick in and everything comes to a hold
when i than try to turn of iray daz crashes. when u pre/render a second time whithout closing and reponing daz it takes (if even) forever before i see anything redert cause cpu kicks in after ram got all data gpu seems to stay dormand at this
i also tryed to reduce the texture sice whit scene optimizer but even on 1/4 of the 2k somewaht size the graficscard (i have a gtx 1070 whit 8GB) cant handle it and all that is in my scene is a genesis 8 figure and the outfit
so since it seems that not the texture seems to be the problem i would like to know why i cant make any renders whit that outfit and if i had blown out anozher 8 bucks.
P.S.: also i would like to know if there is somewaht of a discord server for daz3d
Mod edited to remove unsolicited Off Site Commercial link
Go to the parameters tab of the clothing and look for the subdivision and check if it's too high.
there is render/view subD level and both of them is set to 1 for all parts of the outfit
whitch seems to be just normal so no it seems to have a nother issue
but thx for your input
To be certain that it's not a shader issue, hold down the Control key and apply a shader you know will work. Tell the action to ignore the images. See what happens. Using shaders meant for another rendering engine can cause crashes like this.
sry that it took my that loong to answer
but ok ill gonna try that
all of the surfaces use iray uber as the shader
everypart of the outfit however only has one surface on it and it is using a texture for the entire part
were the texture is is diviging the colors i guess so well to make it clear its very lazely made only one surface
per item... if i exchange the surface to something else like carpaint... it works so yeah seems like even that the
surface tap is telling me it usses iray uber everwere that it acually does not... so now how do i can exchange all of them
whitout ruining the howle outfit
