how can I set big size render output
generally, my pics are 2~3 mb,it lost to much details,when I zoom in the pic,it went pixels... last night ,I try to set higher value in render settings and rendering all night... this morning, I check the render result, it gets more dark but with a little details.but the size is even less than 2 mb,why...?
  • kenshaw011267kenshaw011267 Posts: 3,805
    Are you rendering the image as a jpg?
  • kyoreonakyoreona Posts: 222
    yes,as you said,is that the problem? should I render it as PNG ?
    JPG's are compressed. The size of the file has relatively little to do with the images resolution and high resolution images will have less detail.
    PNG's are not compressed.
    I'd try the scene rendered as a PNG and see if you get the results you desire.
    I have found the reason. It's because I choose the active viewport as render setting
