Looking for a Riverbank
I am unable to find a riverbank, where the earth is undercutcut by the water, and the edge of the grass or ground hangs slightly over.  Ideally, there would be enough textured geometry that the river level could be raised or lowered a bit.  Is there anything like that somewhere?
  • NorthOf45NorthOf45 Posts: 5,920
    edited August 2019
    If you have TerraDome 3 and Terrain-Morphs-Vol2, there is a morph called Rib Shank Valley, the middle scene in the main promo. Add some water, and with the right scale, it could pass for a riverbank. Here's a quick render with Rib Shank Valley at 35% (The ground shader I used is included with TerraDome 3).  The sides get higher and more curved as you dial it in more.
    800 x 450 - 585K
    Post edited by NorthOf45 on
  • Thank you for the suggestion, but I don't use iRay.
