Can't find resource and it's driving me crazy!
I am getting these errors. When I navigate to /Female/Morphs/DAZ 3D/Head/ there is no /Old/ folder. I've looked at everything else and I can't find out what product has this folder in it.
2019-08-25 08:31:20.900 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5759): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Head/Old/PHMEyesIrisSize.dsf#PHMEyesIrisSize?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/vyktohria/Meredith/VYK%20Meredith%20Head.dsf
2019-08-25 08:31:20.900 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5759): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Head/Old/PHMEyesIrisSize.dsf#PHMEyesIrisSize?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/vyktohria/Heaven/VYK%20Heaven%20Head.dsf
2019-08-25 08:31:20.916 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5759): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Head/Old/PHMEyesIrisSize.dsf#PHMEyesIrisSize?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/vyktohria/Dolly%20Mine/VYK%20Dolly%20Mine.ds
  • I am getting these errors. When I navigate to /Female/Morphs/DAZ 3D/Head/ there is no /Old/ folder. I've looked at everything else and I can't find out what product has this folder in it.
    Strange, maybe try to re-download the morph on DAZ install manager.
  • edited August 2019
    I don't know which one it is. I tried searching online.
    Post edited by wolfetundra_297192118f on
  • AscaniaAscania Posts: 1,855
    The name is listed  in the warnings you posted
    I've already installed Genesis 8. There is no /Old/ folder. What am I missing?
  • Those just mean you have a property which has links to another prperty that isn't installed - it doesn't necessarily, or usually, mean anything is broken. Is it (or are they) actually cuasing any issues in this case?
  • NorthOf45NorthOf45 Posts: 5,771
    That particular morph (PHMEyesIrisSize) is in the "data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Head" folder. It is probably an error in the Meredith product where another folder was used during development and was overlooked.
    It's causing a slowdown loading a new character. Otherwise, nothing looks broken.
    I've reinstalled Meredith to no change.
    The Meredith product has to be modified, specifically, the file that calls that morph (/data/DAZ 3D/Genesis 8/Female/Morphs/vyktohria/Meredith/VYK Meredith Head.dsf) needs to be edited to remove the "/Old" from the path. Best to write a support ticket to get it done officially so that everyone can benefit. Meanwhile, you can do it yourself to correct the error and see if it works properly. You can re-install again if you make a mess of things... cheeky
    I'll give that a try this weekend. Hopefully it works.
