Hair poke through situation. (solved)
MortzeMortze Posts: 186
Hey folks,
I wonder if you could help me with this hair poke through situation. What's causing it and how can I avoid it?
Thanks!
Post edited by Mortze on
  • TheKDTheKD Posts: 2,711
    Is your character very far away from the 0,0,0 origin? I have seen transparency go all wonky like that if you are far from the origin and render.
  • PlatnumkPlatnumk Posts: 682
    Its the hairs skull cap poking through,  You need to use the Hairs Adj Morph - Head Size to get it to fit correctly
  • MortzeMortze Posts: 186
    Very very far no but she isn't close to the origin either.
    I did a test with posing the character at 0,0,0, and oddly enough it worked, the hair poke through disappeared. This is really weird.
    Thank you for the tip though!
