Daz no longer saving custom keybinds.
Everytime I set up my own keys in the custom-actions screen and save them, the next time Daz is loaded they are ignored and back to the default settings. This has only just started happening as I had already set some binds setup and they still work fine, something seems to have gone wrong with the actions list.
Every other part of the layout can be customised and saved with no problems, its just everytime I set my own keys up they are forgotten the next time and are back to default. Anyone had anything like this before?
  • Richard HaseltineRichard Haseltine Posts: 111,972
    Which version of DS is this?
  • StormlyghtStormlyght Posts: 666
    edited December 2013
    Hi @Drybonez and @Richard Haseltine,
    I'm having the exact same issue since I upgraded to 4.6.1.39 Public Release candidate. I thought perhaps I had a corrupted installation and was going to reinstall, maybe I need to wait and see if there are any bug reports on this first.
    Trish
    Edited: Grammar
    Post edited by Stormlyght on
    saving custome keybinds could not work about some tools.
    I think , all tools which categorized as View port tools, (which we change setting in tool settiing tabs)
    the short cut modify can not work. (CCT tools, or
    The shortcut bug was fixed in the Dev channel this past Friday. The general public will not see that fix until build 4.6.2.75 (or later) makes its way to either the Public Build channel, or the Production channel. Before that happens, the fix still needs to be verified in the Private Build channel, which is currently testing 4.6.2.72. The Public Build channel is slated to get the 4.6.2.72 build next, so you won’t likely see the fix until the update after next.
    -Rob
    On the other hand other Action can change and save the short cut,
    so that most of users may not find there is some problem.
    Actually I test with 4.6.2.72 but still can not work, (I missunderstand , I need to wait 4.6.2.75 later,,^^;)
