Save Parameters Preset?
asdf123asdf123 Posts: 167
I know how to save Character Presets, however, I'm hoping someone can explain the easiest way of saving multiple Parameter changes into a single button or dial. I'd like to apply the same multiple modifications to different characters and would like to streamline that process.
  • ElliandraElliandra Posts: 642
    If you are referring to shape dials you can use the Save As/Shaping Preset and either use the "Check All Modified" or go in and hand select just the dials you want saved. This will allow you apply the preset to all the characters with the same base figure. However, if the dial is already being used by the currently applied character it will just change the value to the one in the preset you saved out.
  • asdf123asdf123 Posts: 167
    Thanks!!
  • lilweeplilweep Posts: 2,864
    How do you load the saved preset?
  • File>Merge or use the content pnes to find it and double-click, in all cases with the target item loaded and selected.
