The Beastman isn't behaving properly
K T OngK T Ong Posts: 486
edited December 2013 in The Commons
Recently got and installed the Beastman, plus the LAMH free player (which I understand is required for the Beastman's fur to work properly). Opened DAZ Studio. Loaded a Genesis figure. Shaped it to my liking and applied the Beastman skin. No problem so far. Once I tried applying one of the fur presets, though, I got this message:
This preset doesn't match the model it was designed for.
Or, if you have a TriAx figure, make sure it's set at Base Resolution.
Then Daz Studio crashed.
I figured maybe I shouldn't load a Genesis figure, but a pre-made Beastman figure. So I did that and then tried loading the fur preset -- with the same results.
Tried re-installing the LAMH player. (I was careful to use the 64-bit version as I use Windows 7.) Same thing.
What gives? Help, please? Thanks! (Do I really need Freak 5? Haven't got it.)
Post edited by K T Ong on
  • SylvanSylvan Posts: 2,719
    My guess is you really do need Freak 5 for the fur to fit.
  • RenpatsuRenpatsu Posts: 828
    I don't got Freak5 and it works here. I am not sure if the downloaded player via DIM is already the updated one though. Potentially the "beta" is still newer. As I use the full version myself (which latest is the RC2) I don't know that.
    http://www.furrythings.com/lamh-player-1-07-00p-beta-available/
  • K T OngK T Ong Posts: 486
    Tried the .dll file provided by the beta.
    Same thing... :shut:
  • scorpioscorpio Posts: 8,533
    Contact either Kendall or Alessandro AM, they will help you sort it out, you can find them in this thread
    http://www.daz3d.com/forums/discussion/34012/
    they often post their emails so they can supply support that way.
  • DisparateDreamerDisparateDreamer Posts: 2,520
    I've only ever gotten that error if I didn't have the figure selected when I try to apply the preset.....
  • Kendall SearsKendall Sears Posts: 2,995
    I just now tested the Beastman with the DIM version of the LAMH Player and all worked from the presets, both with and without Freak5 available. Feel free to contact me directly: krsears (at) trdc.biz so we can see what the problem may be.
    Kendall
    Post edited by Kendall Sears on
    Okay, maybe I'll try the DIM version first...
    Yup. Problem solved. ;-)
    Gladly. (Sigh...)
    720 x 960 - 1M
  • GreybroGreybro Posts: 2,705
    Did I mention my love for this figure?
    1000 x 786 - 184K
