The Outlander HD
I just bought the The Outlander HD and when I load the G4 male  it starts with the Outlander morph applied. Is anyone else having this problem?
  • G4 ??? what one is that !
  • I meant genesis 8 male Sorry
  • I know what that is it means the morph was saved with it turned on, instead of it at 0. You may need to fill out a ticket. Or maybe wait to see if anyone else has same problem.
  • Escobar87Escobar87 Posts: 18
    edited August 2019
    I`ve the same problem. When you load a G8 Male Base Figure, it has the Outlander Morphs applied right from the start.
    Post edited by Escobar87 on
  • Please report this to Technical Support https://www.daz3d.com/help/help-contact-us
    In the meantime, just zero the morph.
    This has been happening more lately. Wish QA would check for this.
  • hee hee. Sorry, I couldn't help but think... happy halloween.... BOO! Outlander monster in ALL your pictures to scare you forever :)
    ... I'm tired, haven't slept in a couple days, and i'm easily amused. I'm still chuckling to myself. heh. heh.
    It is quite a shocking surprise!   :  0
  • Thank you all.
  • GoggerGogger Posts: 2,533
    +1
    Also, correct spelling of folders and subdirectories MATTERS! (UGH!)
    Seriously, how would we go about getting DAZ QA to implement these checks?
  • Josh CrockettJosh Crockett Posts: 572
    edited August 2019
    Not sure what happened there. Working fine here on my side.
    The easy way to fix this problem is to open up the main morph in a text editor, which can be found in the data folder,  and change the value from 1 to 0 and save it. Then dial up the morph and resave the character preset. If you want to keep the original thumbnail, make sure you copy it out then replace it once your character preset is saved.
    I prefer Notepad++ to do this.
    Hope that helps,
    Josh
    Post edited by Josh Crockett on
