Shoulders aren't round
Sylvan
Ok, I have seen it passing on the forums not long ago, but can't find it back.
At some point I must have changed something because all my figures lost their natural curved shoulders.
This is a screeny from the viewport, but it shows the same squaryness in the renders as well.
I have been fiddeling with resolution but no change so far so I must be looking in the wrong place...
232 x 99 - 5K
If that is Genesis, or Genesis 2. you probably have it set at Basic Resolution.
The Basic Resolution Is 19k, set it to High Resolution and you will be OK.
The picture is Genesis 1.
Strange thing is when I set it to high res, it jumps back and clears the field Oo
I have been tamepring with genesis to convert M5 to G2M.
Did I perhaps overwrite the base somehow, because I remember I had to set it to base resolution when I converted.
I'll try and reinstall Genesis first...hope that it will work.
Possible.
I agree, it looks like the 'base' or lower res version.
Oh boy, I messed something up!
I reinstalled M5 and Genesis, but still I can't set it to the high resolution.
When I try to select the high resolution, the field still goes blanc after I select it...
What do you have selected when you try this? That (3) in all the parameter labels usually means you have three objects or three body parts of an object selected, that will definitely mix up the resolution selection.
