Daz to Mixamo
Who has the answer to the Sphinx's riddle??
There's literally 100 options to adjust and possibly get a Genesis 1-3 in there..
Anyone have the combination plz!?!?
  • GordigGordig Posts: 10,650
    edited August 2019
    What have you tried, and what problems are you having? I've successfully imported G3 and G8 into Mixamo. I assume G1/G2 would be the same, if not easier than at least G8.
    Post edited by Gordig on
    I just exported stock G1 and G2 characters from Daz, and they imported into Mixamo without incident. It's having a little trouble with the G3 character, but that might have something to do with the fact that I decided to make it a ninja turtle.
  • AlfawulfAlfawulf Posts: 174
    We got the Gen 1 in a s FBX changing the sub and cothes toskeleton. Still having trouble in the Gen 2. Gen 3 is a space case FTM...
    edited August 2019
    I suppose it matters how you’re going to use them, as well. If you export a basic, nude, even textureless figure, there’s much less for Mixamo to potentially trip over. Then you can simply import the animation into Daz or your preferred animation program and apply it to figures set up how you want them. There are, of course, potential problems with clothing not (con/de)forming correctly, but I’d recommend at least testing a base figure before worrying too much about the clothing.
    edited August 2019
    So far here's the plan.
    I'd like to use the Gen 2 and 3's mostly. Both I'd like to export to Mixamo and get their animations.
    From there, I'd like to also get characters into Blender.
    Also, apply the animations from mixamo in both Daz and Blender..
    Just need the proper instructions/videos to do so.
    Post edited by Alfawulf on
  • marblemarble Posts: 7,500
    I'd like to know how to do this too - including the Blender bit. This might help ...
    https://www.daz3d.com/forums/discussion/250726/so-if-an-animation-is-saved-using-genesis-it-works-on-genesis-3
