Question about InaneGlory's Photo Studio Bundle
brainmuffinbrainmuffin Posts: 1,326
How useful are the other parts of the InaneGlory's Photo Studio Bundle in LuxRender? I know it has a portion usable with Luxus, but will the other pieces work too or is it best just to get the parts that are marketed to work?
  • InaneGloryInaneGlory Posts: 294
    The way I set the products up was so that if all you were looking for was lighting for LuxRender you had a cheap solution to your need and if you are someone who has no interest in LuxRender you could skip getting Photo Studio Lux without feeling like you were missing out on something. On the other hand the bundled set is a stronger (and easier to use) set if you are not elusively wedded to either render engine but switch back and forth between them as I do :-)
    The 3 groups of light position poses in Photo Studio 1-3 will work with the Photo Studio Lux light rigs and will make positioning the lights for use in LuxRender easier. The three background props and all the texture presets in 1-3 for those props will all auto-convert pretty well with Luxus (but they are also pretty easy to manually convert on your own).
    Most of the other presets (intensity and quality settings etc,) are designed to help set up and adjust your lighting in DAZ Studio only so if all your interested in is lighting in LuxRender they won't be of much use to you.
