How to disable transparency
Hello. I've just imported an .obj from Blender to Daz. but the model became transparent. its not just in viewport. it does the same in rendering. can somebody help me ??
I also dont want to disable transparency on the whole model. the hair contains transparent textures.
the screenshot is attached
1552 x 839 - 244K
  • barbultbarbult Posts: 27,504
    Transparency is controlled in the Surfaces pane. For 3Delight render engine, look at Opacity. For Iray, look at Cutout Opacity. A value of 1 is opaque, as long as there is no transparency map in the channel. If there is a map, delete it for fully opaque textures. Other setting that can cause a semi-transparent look are Refraction and Translucency. Take a look at those.
