haveing to many issues today...
The selection tool....will only select the whole modle not her joint and animatable parts...where do i change this setting for the universal gizmo tool? Thanks
  • FrinkkyFrinkky Posts: 388
    Check 'Window' > 'Panes (Tabs)' > 'Tool Settings' then ensure 'Node Selection' is the active tool. In the drop down titled 'Node Selection Mode:' ensure 'Root Node Only' is NOT selected. I believe the default is 'Root Node First'.
  • 1234MATT1234MATT Posts: 223
    ok thanmk you so much...!
    ok ,, so i my computer...it is "Node" only. Either of the other 2 will not make the right choice i want....really cant figure out how i did that but thanks a buch....!!
