Render times
blue6stringblue6string Posts: 60
Do objects not in the render viewporet window affect render times. I.e. Does having the ground scaled way out, make rendering longer for shots where very little of it will be seen?
  • blue6stringblue6string Posts: 60
    visible in the window that is..... so another object maybe blocking it from from view.
    if it is just not in the shot window at all
  • TotteTotte Posts: 15,274
    3Delight do hidden surface removal, but the more meshes and textures you have, the longer render times, specially of that stuff behind the camera will reflect in items visible. Sometimes that is desired, sometimes not.
