[Tutorial] Importing Kitbash3d products to Daz Studio
Hello,
Step 1 - Importing to Daz Studio
I wanted to share the workaround I found to import kitbash3d props into Daz Studio while keeping the diffuse texture and maintaining each prop separated. I was not able to achieve that using the Daz Studio Importer. If there is a better way, let me know!
This will only make sense for those importing this product, but I believe it is useful information.
First, download the version with FBX + OBJ. Extract the zip file. Open the .mtl file in notepad. Use the search and replace tool to change the directories to the ones you are using. For example, replace K:\KB3D\KB3DTextures\ to C:\Users\Public\Documents\Environments\Brutalist\KB3DTextures\
Now Open Daz Studio. Click on "File->Send to Hexagon", just to make sure that the bridge will work. Hexagon should open now.
After that, select the ".obj" file with your kitbash3d product and drag it to the Hexagon window. The props will load.
Now, on the "scene tree" of hexagon (right column), select everything. After that, click "File -> Send to Daz Studio".
After that, all props should load inside Daz Studio and save the file.
I
Post edited by GutoCrafts on
Hi.
I tried that, but hexagon returned two errors. One about it being unable to load a JPEG, and another about an internal error :(
