problems installing V5
mackeymobmackeymob Posts: 0
I have the latest version of DS 4.6
I'm trying to install V5 I get this message
Victoria5 has a dependency on another product and required files could not be found in the chosen location.
please chose a different install location
what am I missing?
I haven't added anything to 4.6
The standard Genesis works fine.
    V5 is a morph of the original Genesis, and MUST be installed into the same library folder as Genesis, that would appear to be the missing dependency.
    If you are using DIM to install V5, make sure that it is installing it into the same folder that Genesis (NOT Genesis 2) was installed into. DIM by default, installs content into C:\Users\Public\Documents\My DAZ 3D Library, and not into the old My Library folder.
  • Richard HaseltineRichard Haseltine Posts: 111,984
    Actually, TriAx figures such as Genesis can have their morphs spread over multiple content directories (that wasn't true of the older figures). The DAZ Install Manager doesn't enforce using the same directory for all, and I'm pretty sure that V5 has been updated since the switch to zips so i would advise downloading afresh, using DIM or manually unzipping.
