dynamic cloth control
Hi, i had purchased the pro version of the Optitex Dynamic cloth control. how ever in Daz 4.11 only the basic version of the pugin is used. I also tryed the 32 bit ver sion of 4.11,,, not even available at all in there. What do i do?...oopps yes i know learn the dforce system....i am working on that... Thanks matt123
  • LeanaLeana Posts: 13,499
    Did you install the plugin? If yes, did you activate it by entering the corresponding serial number in DS?
  • 1234MATT1234MATT Posts: 222
    there was no seial number to activate, there was no plugin to down load,,,it was activated by my seial number for daz studio.
    and it was the basic one
    There is definitely a plugin to install to get the complete version. You should find it in your product library or in DIM now that you’ve purchased it (you can’t install plugins with Connect, if that’s what you usually install content with).
    Serial number should be available from the Serial Number page in your account.
    ok, i get it now. i did exactly that,,,however Daz crashes every time i try to use it,....so sad lolohaha
    what next? thanks 1234matt
  • What is the full version number of DS - Help>About Daz Studio?
    edited August 2019
    hi, here is the full version number...4.11.0.383 Pro edition 64 bit. ..i did manage  to install the full control....but it crashes quite a bit.....thinking about switching to dforce,,but its all about time to get it together cause the docs are so spread out.
    Post edited by 1234MATT on
  • Have you tried a simple item? I have had stability issues in the past (pretty sure I haven't tried in the current version) with some of the more complex items.
    edited August 2019
    tryed 2 types. bikinie and teddy or shirt as it is called, but not the century gown or an other,,,it was great for a long time,,maybe should switch to dforce?
  • Most OptiTex items will work in dForce, but you do lose features (such as the style-switching).
    ok, thanks. i would settle for any thing that just worked at this moment.
