Skin Builder for Genesis 8
Coryllon
I am trying to use the eye brows portion of this, however it does not remove the old brows so instead my character has 2 sets of eye brows, not the most awesome thing ever.
Also, why does the multiplicative (I think it's called) blend not work, only the Normal?
Post edited by Coryllon on
You would need to remove the brows from the texture yourself, perhaps using the Brow remover product.
In what context is multiply not working?
Any context I guess? it just does not work. it does not apply. the only way to add brows is to use normal.
Additionally (always something) I can't seem to get grey skin. it always has a flesh-tone to it even though all colors I use are on the black to whte scale. any thoughts?
Have you set the skin to "pale" so that it uses the white base skin?
not yet, I wasn't sure what that did and honestly I made so many changes trying to make it work that I crashed my Daz... So I will try that today.
The settings above the colors determine how to create the bottom layer of your skin texture: the product includes 4 base skins (white, light, medium and dark) and will use one / blend them depending on the settings you chose.
If you want a white texture then you need to set the "Pale skin" slider to 100% so that it only uses the white base.
ok so Pale fixed the look of the skin. but now if I try to add white eyebrows they barely show up. if you didn't know you added them you would never see them. This is with visability at 100 and brow height ranging from 0 to 50
anyone else have this issue?
