How to change tab-window Z position, or hide behind the main window?
kitakoredazkitakoredaz Posts: 3,526
I often separate panes of daz studio,(mix shader or timeline etc) and set undockable ,so that I can open many tab as window,
and arrange them in monitor 2D space, but there seems no way to change z-layer position of each sub windows.
I expect, when I select DS main window, now the window turn active,
then these divided pane windows should be hidden behind the main ds window,,
but,, once I separate misshader tab, or others, these sub windows always cover ds main window,,
Is there setting option,,to change the behavor?:roll:
eg,, Now I open IE, Blender, and DS, then I select one aprication, the Active window must turn up in front of all.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,663
    yes I noticed this too
    very annoying,
    Poser and iClone do not do this
    been using studio a bit more lately
    fortunately I have two monitors
