How can I tell which parameters are not set to the default?
I played with morphs, shapes and after applying 5-10 things, something came out that I like.
 How can I tell which morphs I ended up with without having to go through the whole G8 parameter list?
I want to know something like this:
Victoria 8 is at 80%
Big smile 30%
etc...
  • Dim ReaperDim Reaper Posts: 687
    Click the figure in the Scene tab, then go to the Parameters tab and click "Currently Used" at the top - this will show only those morphs that the figure is using at the time.
  • XelloszXellosz Posts: 855
    Thx.
  • The tone of the number gives it away - non-defaults, even if zero, are brighter than defaults. Currently Used should show the non-zero values.
