Is it still possible to do a manual download without install manager?
sdspsdsp Posts: 0
I'm trying to download latest Daz Studio version 4.6 Pro. But it is only allowing me to download the install manager. Nothing happens when I click on the little button that says "To install DAZ Studio Pro manually click here."
My account does show new serial numbers for 4.6 but no new invoice appears which lists the program for download.
Is it no longer possible to manually download and Install Daz Studio?
  • frank0314frank0314 Posts: 15,101
    edited December 2013
    You should be able to manually download. You can download it with DIM and then just install it manually and not with DIM. The latest beta release is for DIM only
    Post edited by frank0314 on
  • sdspsdsp Posts: 0
    What is the procedure for manually downloading it? Where do I find the download?
    When I click the link that says manual download nothing happens, and now links are added to my account.
    506 x 411 - 34K
  • reelyorreelyor Posts: 237
    I don't use the CIM.
    After you make the purchase, go to your accounts page and select "Product Library" at the top of the page.
    You will be taken to a list of the products you have purchased that are in your library.
    On the left, you can select the product you just purchased, which will come up. At the bottom, you will see links for both MANUAL download and CIM install. Select the appropriate Manual download (blue) link.
    After download, you will still have to unzip the file and then install. (I usually just open right click the file, which opens the folder, then click on the Content directory, which now shows the Runtime folder. I drag that folder, and any others, over into the Daz Studio Content foder.
    Hopefully, I understood upir question correctly.
  • sdspsdsp Posts: 0
    Ok - Apparently I can get access to the manual downloads for 4.6 only after clicking on the old link for 4.5.
    No new link for 4.6 appears at all in my account. I have to use the old link.
    FYI - I did already just use the Download Manager and it was pretty painless. But I still like having the actual program installers if they are ever needed.
    You can save the zips in DIM. By default is saves all downloads, so you will always have the zip unless you tell DIM to delete upon install
