Musubi style hair?
RPGMaker247RPGMaker247 Posts: 146
edited August 2019 in The Commons
I'm working on a character loosely based on the character Musubi from the series Sekirei/Sekirei Pure Engagement. Is there hair such as what the character has? Bob style with long tail at base. Also like Kaede's hair from Negima series.
1280 x 720 - 38K
162 x 310 - 14K
Post edited by RPGMaker247 on
  • MimicMollyMimicMolly Posts: 2,380
    edited August 2019
    I don't know of any hair that matches that style, but you can probably try to make something similar with a bob haircut (fitted or parented) on top of a low-ponytail. Then add a hair shader to both so they can match on color. You might need to make the opacity at 0% on the front of the ponytail. Unfortunately, I don't have a low-ponytail on this computer, but hopefully you get the idea.
    1000 x 1307 - 899K
    1000 x 1307 - 901K
    Post edited by MimicMolly on
  • I don't know of any hair that matches that style, but you can probably try to make something similar with a bob haircut (fitted or parented) on top of a low-ponytail. Then add a hair shader to both so they can match on color. You might need to make the opacity at 0% on the front of the ponytail. Unfortunately, I don't have a low-ponytail on this computer, but hopefully you get the idea.
    I'll give it a try-thanks for the idea.
  • SevrinSevrin Posts: 6,314
    Razor-Cut Bob Hair for Genesis 3 Female(s) gets you most of the way there.  It's kind of messy, which is right.  Most of the hair with side bangs on Daz is much smoother and is too long or short  on the sides, like Nyo Hair.
