Is there a way I can make a clothing morph for a posed character
Hi,
   I'd like to make a "sitting" morph for a skirt I modeled.
Is there a way I can take through GOZ a posed Genesis 8 with the skirt and make the morph in ZBrush.
I understand the process of morphing without the pose but would like to be able to add the sitting morph.
Cheerio
lululee
  • SixDsSixDs Posts: 2,384
    Before trying to create a morph, you may wish to try simply applying the same pose to the garment that you are using for the figure.
  • xmasrosexmasrose Posts: 1,409
    edited August 2019
    Post edited by xmasrose on
  • lululee1lululee1 Posts: 346
    Hi SixDs,
       I applie the same pose to the skirt but it went a bit wonky.
    Cheerio
    lululee
  • felisfelis Posts: 6,497
    Any reason for not using dforce on the clothing?
    Hi tulip,
       Thanks so much, I'll check that video out.
    Felis,
      I do have dforce on the skirt. I'll probably just stick with that.
    Thanks for reminding me.
    Cheerio
    lululee
  • Valery3DValery3D Posts: 105
    lululee1 said:
    Hi tulip,
    Felis,
    Cheerio
    yes that is possible you use the goz bridge and morph it in the sitting position and once your done import it back in via morphloader pro but Now click Yes instead of no within the option that says reverse deformation
    lululee1  Sorry didn't see you had ZBrush
    This old video could help you : Repair bad deforming clothing from Autofit using GOZ by MEC4D
