Rampaging Elf Ears
Sevrin
So, I have this thing the past day or so where my GF8 and any character based on it, including V8, etc, load with elf ears. I've tried reinstalling G8 Starter Essentials, but that hasn't worked. I have to zero out the figure, and then go load specific character morphs from the Content Library. Now I did install a G8 character from Rendo that comes with elf ears recently, but I didn't apply them, as far as I remember. I may have. Whatever.
What must I do to relieve myself of this problem?
Have you recently installed a new character or morph set? It's likely that the issue is a morph with a non-zero default value, that may be a product error in a new product or it may be that you changed a value and accidentally hit File>Save As>Support Assets>Save Modified Assets. The fix is identify the problem morph, which you should be able to do by looking at the Currently Used group in the Parameters pane with a newly loaded base figure selected, and:
As per my post, I did install a new character that comes with elf ears.
I will bring it up with the maker. Thanks.
Sorry, I missed that.
Uninstalling worked. I've sent a note to the vendor to see if anything can be done.
I'm not much of one for elf ears. If I just reinstall without the elf ear morph, should that work?
Yes, it't the actual .dsf file for the ears that has the undesired default value
