Help with V4.2 and V6
michaelmirandamichaelmiranda Posts: 0
I have the Victoria 4.2 starter bundle and Victoria 6 Pro Bundle installed on a Windows 7 machine. (64 bit)
All of the morphing sliders for V4 are not there anymore. If I load V4 into a scene and click the shape tab, there are only two options on sliders (Male Body and Male Body No Scale).
V6 looks like all the morph sliders are there.
I had V6 installed prior to V4. And the first time I put V4 in a scene, the sliders were there. Now they are not.
Also had a few issues with the basic underwear set and hair (Amarseda V4)came with V4. When I double click to load them, they load, but are not fitted properly to V4. If I do the "fit to V4" they look ok until I load a pose. The model does the pose but the hair and clothing stay where they were in the first pose and look as if they're not on the model.
Before installing the V4.2 Starter bundle, things seemed to be working fine.
Any insight or help would greatly be appreciated.
    You need to inject the Morphs into V4. If you only have the starter bundle then you will, I think, only have the base morphs, but they need to be injected from your Pose library. Runtime / Library / Pose / Daz's Victoria 4 / Morph injections
  • mark128mark128 Posts: 1,033
    edited December 2013
    As chohole indicated, you need to inject the poses into Victoria 4.2. There is an auto injection dialog that comes up when I load V4.2, but it has a check box to disable it. I'm guessing the first time you auto loaded all the morphs, but checked the box not to ask again.
    There is a pose to inject the moprhs in Poser formats -> -> Pose -> DAZ's Victoria 4 -> Morph Injections
    Genesis 1 and Genesis 2 do not have morph injections. They just always load with all the morphs already loaded.
    Post edited by mark128 on
  • michaelmirandamichaelmiranda Posts: 0
    Thank You! That did the trick.
    Also, when I went looking for the Morph injections, I found the "Magnetize to V4" Looks like this solved the clothing coming off issue.
    Still having the hair come off when loading different poses.
    Some hair "fit to" V4.2, some are "parented to" the head.
