Layered Image Editor ?
I'm attaching three pictures.
Shirt 1 is of a shirt using a military pattern that too big for the shirt.
Screenshot is where I opened the Layer Image Editor and change the 100% to 50% on the X and Y Scale.
What I end up with is shirt 2 picture. Where the texture only shows up on a small part of the shirt instead of a smaller pattern.
I've also messed with the document size with no real luck. The texture always ends up blurry.
Any thoughts? Am I misunderstanding what the X and Y scale is suppose to do.
Thanks
790 x 733 - 120K
600 x 485 - 209K
790 x 733 - 168K
I'm afraid that the L.I.E. does not tile the texture. So it could be used to take an image and make it a logo/patch on the t-shirt, but it isn't going to take a small swatch and replicate it across the whole shirt. If you need it to cover the whole shirt, you'll have to create the tiled texture using a paint program then you can use L.I.E. to apply your new image to the shirt.
Thank you, I understand how it works now.
