problem with feet posing, pose for specific shoes won't go away
ps2000ps2000 Posts: 278
Hello,
I have a strange problem with posing the feet. I applied some high heel shoes to a character (Carly High Heels) and the feet got into the right pose for the specific shoes automatically. But after removing the shoes I can't alter or zero the feet pose (Zeroing select items pose under edit -> figure -> Zero does nothing. I only can change the pose manually under Parameters or Posing pane.
But it gets stranger: After manually zeroing the feet pose I can't load a feet pose for other shoes. If I select the feet pose for some non-heel sport shoes for example it restores the old feet pose for the High heel shoes. Also loading another feet pose when the feet are still in the carly high heel pose does nothing. The pose stays the same.
It's slightly annoying.
Has somebody an idea how I can fix this? Or have i buggered my character?
Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,862
    That sounds as if there's a morph or a pose control for the feet, rather than posing the bones individually. Select the figure node and check what's listed in the Parameters pane in the Currently Used group.
