Link Paramaters of two seperate objects?
dodgerrecordsdodgerrecords Posts: 123
Is there a way to link the paramaters together of two seperate objects? Like say I have a shirt, and the shirt has a morph to bulge the stomach out, and then I have a morph on my character to bulge the stomach out, how would I make it so that when I bulged the stomach on the character it would automatically bulge the shirt?
Much thanks if you can shed any insight.
  • Richard HaseltineRichard Haseltine Posts: 111,598
    As long as the morphs have the same name (not label, the actual name - you can check that by opening Parameter Settings from the gear icon on the slider) and the shirt is fitted to the figure the shirt morph will follow.
  • dodgerrecordsdodgerrecords Posts: 123
    Do you know where the property editor is in Daz 4.6? I can't find it anywhere, I really wish they wouldnt move things around every release.
    Property Editor has been replaced with Property Hierarchy and Edit mode for the Parameters pane, to better handle figures with a lot of morphs.
