Can't get expression back from zeroed figure...
ZaiZai Posts: 289
OK so this is a really weird problem and there may not be an actual solution, but here's hoping!
I made an expression for G8M and saved it out. Somewhere along the line I had used a "zero dials" setting on the figure, instead of zero pose. Apparently, I used it before I saved the expression out. So...the end result is while it saved a file, it saved all zero dials and it doesn't work on a new clean base. OK fine....that makes sense.
But...I still have a scene with a figure in the same pose and expression. I check it...and it has EVERYTHING set to zero, including the expression. It IS in the pose and has the expression, but it's just all set to zero. I was trying to get the expression back so I can resave it. So I tried saving the pose out again. It works....loads on a new base and everything, the pose is there and the expression is loaded. But...it shows all zero dials..LOL.
That means it MUST be saving the info SOMEWHERE. So I went looking for any hidden dials and came up with basically nothing. The body has a few but not the face.
Anyone have any ideas? I'm hoping not to have to recreate the expression since I had it perfect :( It's so annoying because even though I can see it right in front of me I can't get at it. I'm just sitting here giving DS dirty looks wanting to yell... GIVE IT BACK!
Post edited by Zai on
  • Richard HaseltineRichard Haseltine Posts: 108,856
    Are you checking both the local sldiers and the pose controls on the figure? There's a way to bake rotations, so that a pose shows zero rotations, but that doesn't work for morphs so I don't think it can be what is happening here.
  • ZaiZai Posts: 289
    Sorry hadn't gotten back to this, Richard. Thanks for the help...so..here's the deal...
    I checked every dang dial and there's no values anywhere. I then went in and checked the pose file manually to see what I could see. In the text, there ARE numbers..but they are sort of useless to me. See example below:
    "url" : "name://@selection/rLipUpperOuter:?translation/x/value",
    "keys" : [ [ 0, 0.4813001 ] ]
    "url" : "name://@selection/rLipUpperOuter:?translation/y/value",
    "keys" : [ [ 0, -0.4229089 ] ]
    "url" : "name://@selection/rLipUpperOuter:?translation/z/value",
    "keys" : [ [ 0, 0.2123827 ] ]
    I could pick them out and recreate the expression, except they have values on all 3 axis's and there's no way to dial that in. I thought maybe I could do like in/out on z, up/down on y or something weird like that, but then you bring in right/left etc., etc. I don't think it's really possible (at least not easily) to back into the expression this way, even though I do have SOME numbers.
    In the end I finally just recreated the expression as best I could. Trust me to break things! Moral of the story....RUNNNN far away from things that say "Zero DIALS" if that's not REALLY LITERALLY what you intend to do...LOL!
  • ZaiZai Posts: 289
    Also FYI..this was just an expression created with basic daz standard dials - no vendor expressions or baked dials.
